To network card allows the device to access wireless networks. To access this part the rear cover will need to be removed.
Push orange locking tab with spudger right, until battery lifts out of place.
Unscrew the two 7 mm long #0 Phillips screws.
Lift and remove the cover panel via the indentation in the middle of the panel.
Dislocate the white wire by pushing upward away from the network card.
Dislocate the black wire by pushing upward away from the network card.
Unscrew the 3 mm long #0 Phillips head screw.
