Both the battery and rear cover guides should be completed before completing this guide. This guide can be used for replacing a dying hard drive or upgrading your current hard drive.
Push orange locking tab with spudger right, until battery lifts out of place.
Unscrew the two 7 mm long #0 Phillips screws.
Lift and remove the cover panel via the indentation in the middle of the panel.
Push spudger to the left until hard drive is moved from its original position.
Pull plastic flap and pull hard drive away from laptop.
