Gateway NV55C49u USB Port Replacement
  1. Gateway NV55C49u USB Port Replacement, USB Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u USB Port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  5. Gateway NV55C49u USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all nine 6.0mm #00 Phillips screws from the back of the laptop.
  6. Gateway NV55C49u USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over so that the cover faces you.
    • Open the laptop so you can see the keyboard.
  8. Gateway NV55C49u USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push in the tabs that are located around the keyboard using the triangle scalpel tool.
    • This should release the keyboard so it can be pulled up
  9. Gateway NV55C49u USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift up the keyboard away from the laptop.
    • Push on the sides on the black ribbon cable using 2 plastic opening tools to release it.
  10. Gateway NV55C49u USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 ribbon cables that are showing using the plastic opening tools.
  11. Gateway NV55C49u USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u USB Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the disk drive cover on the right side of the laptop using the plastic opening tool.
    • Slide the disc drive out of its compartment, using the metal spudger.
  12. Gateway NV55C49u USB Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the face plate off the laptop body.
  13. Gateway NV55C49u USB Port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 6.0 mm Phillips #00 screw that holds in the USB port.
  14. Gateway NV55C49u USB Port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push on the sides of the white ribbon cable that is attached to the motherboard using the 2 plastic opening tools to release it.
Micaela
crwdns2935283:010/16/18crwdne2935283:0
329 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S8-G1, Riccardelli Fall 2018 crwdns2935289:0University of North Texas, Team S8-G1, Riccardelli Fall 2018crwdne2935289:0
UNT-RICCARDELLI-F18S8G1
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 805
