Gateway NV55C49u Display Replacement
  1. Gateway NV55C49u Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery
  4. Gateway NV55C49u Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
  6. Gateway NV55C49u Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
  7. Gateway NV55C49u Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.0mm #00 Phillips screws from the area under the back cover.
  8. Gateway NV55C49u Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the nine 6.0mm #00 Phillips screws from the back of the laptop.
  9. Gateway NV55C49u Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are 6 small clips that holding the top row of the keyboard in place.
    • To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
    • Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
  10. Gateway NV55C49u Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the keyboard is loose, slowly lift the keyboard away from the laptop.
    • There will be a single ribbon cable connecting the keyboard to the laptop body. Use two plastic opening tools to loosen the fastener,
    • After the fastener is loose, gently disconnect the cable.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much pressure.
  11. Gateway NV55C49u Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
    • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force.
    • Use a plastic pry tool to disconnect the single pinned connector.
  12. Gateway NV55C49u Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to remove the disk drive cover on the right side of the laptop.
  13. Gateway NV55C49u Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to pry upwards on the disk drive until you can grab and remove it.
  14. Gateway NV55C49u Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now simply lift the face-plate off the laptop body.
    • This step exposes the motherboard, which is a sensitive part of the laptop. Make sure not to touch anything with your bare hands as a static shock could ruin the board.
  15. Gateway NV55C49u Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon wire that connects the display to the motherboard using two plastic opening tools.
  16. Gateway NV55C49u Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV55C49u Display Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.0mm #00 Phillips screws from both the top right and top left of the exposed laptop body.
    • The display is now fully disconnected.
Matthew
crwdns2935283:009/23/18crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S8-G1, Riccardelli Fall 2018 crwdns2935289:0University of North Texas, Team S8-G1, Riccardelli Fall 2018crwdne2935289:0
UNT-RICCARDELLI-F18S8G1
crwdns2942667:0crwdne2942667:0 481
