Gateway NV53A24u Fan Replacement
  1. Gateway NV53A24u Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV53A24u Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
  2. Gateway NV53A24u Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the spudger, lift the keyboard from its base to expose the underside components.
  3. Gateway NV53A24u Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV53A24u Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
    • Then, lift off the shroud to reveal the motherboard beneath.
  4. Gateway NV53A24u Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV53A24u Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard is now readily accessible to be removed.
    • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
  5. Gateway NV53A24u Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV53A24u Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard up and flip it on its back.
    • With the motherboard flipped, the fan is almost ready to be removed.
  6. Gateway NV53A24u Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NV53A24u Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the fan and its copper heat pipe running just behind it.
    • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
Minh Harper
crwdns2935283:010/11/16crwdne2935283:0
156 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-5, Leahy Fall 2016 crwdns2935289:0USF Tampa, Team 1-5, Leahy Fall 2016crwdne2935289:0
USFT-LEAHY-F16S1G5
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 675
