Gateway NV52 Hard Drive Replacement
crwdns2869540:0crwdne2869540:0: 4.3K
3
20
98
4,296
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:05crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937585:0crwdne2937585:0
There will be prerequisites that you need to be complete before displacing the Hard Drive. The prerequisites are available to you in the repair guide manual.
    1. Gateway NV52 Hard Drive Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
    2. Gateway NV52 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up the base cover from the the top with your hands to a 90 degree angle.
      • Remove the base cover and place it in a safe and dry place.
    1. Gateway NV52 Hard Drive Replacement, Hard Drive Compartment: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
    2. Gateway NV52 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NV52 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NV52 Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
      • Lift the Hard Drive to a 90 degree angle and out of its slot.
      • Place the Hard Drive in a designated zone.
    1. Gateway NV52 Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
    2. Gateway NV52 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
Irma Marin
crwdns2935283:004/10/14crwdne2935283:0
608 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-24, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 7-24, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S7G24
crwdns2935297:0108crwdne2935297:0
crwdns2936753:030crwdne2936753:0 98
crwdns2959996:0crwdne2959996:0 4,296
