Gateway NE56R27u Screen Replacement
  1. Gateway NE56R27u Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE56R27u Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, push the orange tab to the unlock position.
  2. Gateway NE56R27u Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery from its compartment.
    • When reinstalling, insert back end of battery first, then clicking into place.
  3. Gateway NE56R27u Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NE56R27u Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NE56R27u Screen Replacement, Screen: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, remove the protective caps for the screen to expose the screws.
    • Using the Phillips #000 screwdriver, unscrew the bottom two 1mm screws.
  4. Gateway NE56R27u Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the opening pick in between the front cover and bezel, gently loosen and lift the plastic bezel from the screen and backing.
  5. Gateway NE56R27u Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the frame of the screen from the top to unhook the frame from the base.
    • When reassembling, hook the bottom of the screen to the base of the laptop before snapping into place.
  6. Gateway NE56R27u Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws in the front corners of the metal frame.
    • Lift the screen slightly to expose the connector board.
  7. Gateway NE56R27u Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, carefully remove the webcam connector from the metal frame.
  8. Gateway NE56R27u Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the tape covering the display cable, releasing the wire from the metal frame.
    • Unplug the display cable from the image processing board on the screen.
  9. Gateway NE56R27u Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE56R27u Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #000 screwdriver, unscrew the four 1 mm screws from the sides of the metal frame.
    • Remove the screen from the metal frame.
Piper Moeller
crwdns2935283:001/24/20crwdne2935283:0
619 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G2, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G2, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S6G2
crwdns2942667:0crwdne2942667:0 345
