The main functionality of your Gateway NE56R27u depends on your ability to use the keyboard. Thus, if you find that your Gateway laptop is not typing properly, certain buttons no longer work, or you now have a short circuit due to damage, replacing your keyboard might resolve such issues. This will allow for a faster and easier operation of your device.
Using the spudger, push the orange tab to the unlock position.
Lift the battery from its compartment.
Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
Use the opening tool to gently pry open the compartment covering.
Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
Flip your laptop over to view the keyboard.
Using the spudger, push in the ten tabs at the edges of the keyboard.
Using the opening pick, lift the edges of the keyboard.
Repeat around the edges of the device.
Lift up the keyboard to expose the cables underneath.
Release the clamp holding the mini-DIN cord by lifting the two black tabs on either side.
Gently pull the mini-DIN cord out of the clamp.
Remove the keyboard.
