The hard drive is how you store data in your device. If you have experienced a hardware failure or you simply want to upgrade your Gateway NE56R27u’s hard drive, this guide will allow you to replace your laptop’s hard drive. Upgrading your hard drive can allow your device to run with increased speed and capacity and with more space to store files.
Using the spudger, push the orange tab to the unlock position.
Lift the battery from its compartment.
Unscrew the two 7.9mm Phillips #0 screws that secure the service cover.
Use the opening tool to gently pry open the compartment covering.
Unscrew the two 0.5mm screws from the hard drive brackets using the Phillips #0 screwdriver.
Pull the plastic tab attached to the hard drive to the right to remove the hard drive.
Remove the hard drive by lifting up the right side, releasing the hard drive from the compartment clips on the left.
