Gateway NE52214U Fan Replacement
  1. Gateway NE52214U Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52214U Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Fan Replacement, Upper Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52214U Fan Replacement, Upper Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Fan Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52214U Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
  8. Gateway NE52214U Fan Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
  9. Gateway NE52214U Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52214U Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the fan and disconnect the fan from the motherboard.
    • Remove the fan from the device.
Kelsey Rodrigues
crwdns2935283:010/23/18crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G1, Simcock Fall 2018 crwdns2935289:0UMass Dartmouth, Team S1-G1, Simcock Fall 2018crwdne2935289:0
UMASSD-SIMCOCK-F18S1G1
crwdns2942667:0crwdne2942667:0 211
