Gateway NE52203u USB Port Replacement
  1. Gateway NE52203u USB Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over onto its backside in order to access the battery.
  2. Gateway NE52203u USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52203u USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
  3. Gateway NE52203u USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
  4. Gateway NE52203u USB Port Replacement, Touchpad Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52203u USB Port Replacement, Touchpad Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  5. Gateway NE52203u USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  6. Gateway NE52203u USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52203u USB Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  7. Gateway NE52203u USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  8. Gateway NE52203u USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NE52203u USB Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NE52203u USB Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
  9. Gateway NE52203u USB Port Replacement, USB Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52203u USB Port Replacement, USB Port: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, pry the ZIF connector upwards.
  10. Gateway NE52203u USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
  11. Gateway NE52203u USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
  12. Gateway NE52203u USB Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, remove the old USB port.
Stephen Spees
crwdns2935283:003/20/15crwdne2935283:0
542 crwdns2915208:0crwdne2915208:0
Baylor, Team 2-1, Grigsby Spring 2015 crwdns2935289:0Baylor, Team 2-1, Grigsby Spring 2015crwdne2935289:0
BU-GRIGSBY-S15S2G1
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 877
