Gateway NE52203u Touchpad Assembly Replacement
  1. Gateway NE52203u Touchpad Assembly Replacement, Touchpad Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52203u Touchpad Assembly Replacement, Touchpad Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  2. Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  3. Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  4. Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  5. Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway NE52203u Touchpad Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
Stephen Spees
crwdns2935283:003/20/15crwdne2935283:0
542 crwdns2915208:0crwdne2915208:0
Baylor, Team 2-1, Grigsby Spring 2015 crwdns2935289:0Baylor, Team 2-1, Grigsby Spring 2015crwdne2935289:0
BU-GRIGSBY-S15S2G1
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,107
