Gateway MS2285 RAM Replacement
    1. Gateway MS2285 RAM Replacement, Turn Laptop Over: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the laptop over so that the underside is facing towards you.
    2. Gateway MS2285 RAM Replacement, Unlock The Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 RAM Replacement, Unlock The Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the short slider one towards the unlocked lock symbol.
    3. Gateway MS2285 RAM Replacement, Release The Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 RAM Replacement, Release The Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the long slider towards the unlocked lock icon.
      • This slider is spring loaded and may require a little force.
      • If done correctly, a click will be heard and the battery will be slightly raised.
    4. Gateway MS2285 RAM Replacement, Remove The Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 RAM Replacement, Remove The Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grasp the battery's raised end and lift upwards.
    1. Gateway MS2285 RAM Replacement, Unscrew Backplate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 RAM Replacement, Unscrew Backplate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the phillips head screwdriver to remove the five screws holding the back plate.
      • The screws are counter-clockwise threaded.
    2. Gateway MS2285 RAM Replacement, Remove Back Plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Remove Back Plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Remove Back Plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place fingers under back plate via the indentation and lift upwards to remove.
    3. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the upper RAM module's two pins outwards at the same time.
      • If done correctly, the module should have lifted.
    4. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 RAM Replacement, Remove Upper RAM Module: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab onto the module and pull away in a straight direction.
      • Do not touch the gold connectors.
    5. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push the lower RAM module's two pins outwards at the same time.
    6. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Like removing the upper module, grab the module and pull away in a straight direction.
Chris mello
crwdns2935283:010/22/14crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-7, Shastany Fall 2014 crwdns2935289:0UMass Dartmouth, Team 1-7, Shastany Fall 2014crwdne2935289:0
UMASSD-SHASTANY-F14S1G7
crwdns2935297:036crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 3,078
