Gateway MS2285 Hard Drive Replacement
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Release The Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Remove The Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
Chris mello
crwdns2935283:010/22/14crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-7, Shastany Fall 2014 crwdns2935289:0UMass Dartmouth, Team 1-7, Shastany Fall 2014crwdne2935289:0
UMASSD-SHASTANY-F14S1G7
crwdns2942667:0crwdne2942667:0 3,980
