The Central Processing Unit (CPU) is an integral part of your computer's speed and ability to process information. A damaged CPU may cause your computer to become slow and unstable, resulting in frequent crashes or even inability to boot. Replacing the CPU will enhance the speed and overall performance of your device. Because of its importance, it can get very expensive to replace. This simple and easy-to-follow guide that requires no special skills will walk you through the steps of replacing the CPU for a Gateway MD2614u.
Place the laptop so the back cover is facing up.
Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
The fan is permanently attached to the silver heat sink next to the RAM.
To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
Pull the fan and heat sink toward you at a 20 degree angle upward.
crwdns2935267:0crwdne2935267:0Flathead 3/32" or 2.5 mm Screwdriver$5.49
The CPU is located under the heat sink you just removed.
Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
Place your fingers on opposite edges of the green card.
Carefully lift the CPU upward.
Memory address registers and memory data registers together can represent the gateway?if can how?
