Gateway MA6 Laptop Cooling Assembly Replacement
  1. Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  2. Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull upwards on the top of the back cover to remove it.
  3. Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
  4. Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
    • Gently flip the cooling fan assembly upside-down on the computer surface.
    • Carefully grab the wire attached to the computer and pull away from the port.
    • The cooling fan is now safe for removal.
  5. Gateway MA6 Laptop Cooling Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
    • If your unfamiliar with applying thermal paste How to Apply Thermal Paste
Chris Naughton
crwdns2935283:004/07/14crwdne2935283:0
724 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-2, Forte Spring 2014 crwdns2935289:0Cal Poly, Team 6-2, Forte Spring 2014crwdne2935289:0
CPSU-FORTE-S14S6G2
crwdns2935297:020crwdne2935297:0
crwdns2942667:0crwdne2942667:0 941
