Gateway ID49C07U Screen Replacement
  1. Gateway ID49C07U Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway ID49C07U Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the tape back with one hand and pull the connector out
Ryan Howlett
crwdns2935283:003/06/17crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 crwdns2935289:0UMass Dartmouth, Team S6-G4, Isaacson Spring 2017crwdne2935289:0
UMASSD-ISAACSON-S17S6G4
crwdns2942667:0crwdne2942667:0 428
