Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
Locate the switch on the top left of the laptop labeled with a padlock symbol.
Flip the switch in the direction of the unlocked padlock symbol.
Locate the switch that releases the battery and slide it to the right.
While holding the release switch to the right, pull the battery away from you.
