Gateway GWTC116-2BL Touchpad Replacement
  1. Gateway GWTC116-2BL Touchpad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flick open the bracket and peel back the white cable.
  7. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the metallic tape off of the casing.
  8. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the smaller piece of metallic tape that was underneath the other tape.
  9. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool, dislocate the touchpad from the adhesive part of the base.
    • Repeat on the other side.
  10. Gateway GWTC116-2BL Touchpad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull away the touchpad from the base of the computer.
Kailey Sousa
crwdns2935283:003/22/24crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-2, Botvin Spring 2024 crwdns2935289:0UMass Dartmouth, Team 6-2, Botvin Spring 2024crwdne2935289:0
UMASSD-BOTVIN-S24S6G2
crwdns2942667:0crwdne2942667:0 202
