Gateway GWTC116-2BL Display Replacement
  1. Gateway GWTC116-2BL Display Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Display Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Display Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
  7. Gateway GWTC116-2BL Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
  8. Gateway GWTC116-2BL Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
  9. Gateway GWTC116-2BL Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
  10. Gateway GWTC116-2BL Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
  11. Gateway GWTC116-2BL Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the black piece of tape covering the display cable.
  12. Gateway GWTC116-2BL Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway GWTC116-2BL Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
  13. Gateway GWTC116-2BL Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the device.
  14. Gateway GWTC116-2BL Display Replacement, Display: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove seven 3.0 mm Phillips #00 screws from the laptop.
  15. Gateway GWTC116-2BL Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Applying some force, use your hands to pry the display of the laptop away from the base.
Kailey Sousa
crwdns2935283:003/22/24crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-2, Botvin Spring 2024 crwdns2935289:0UMass Dartmouth, Team 6-2, Botvin Spring 2024crwdne2935289:0
UMASSD-BOTVIN-S24S6G2
Mon écran ne s'allume pas au démarrage. Que faire ?
Youssouf SAWADOGO - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 776
