Gateway 600YG2 Top Case Replacement
  1. Gateway 600YG2 Top Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over.
    • Slide the battery release tab to the right to open the battery cover.
  2. Gateway 600YG2 Top Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover using the tab on the right side.
    • Lift and remove the battery.
  3. Gateway 600YG2 Top Case Replacement, Power Button Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, from the right and moving to the left.
  4. Gateway 600YG2 Top Case Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws holding the keyboard in place.
  5. Gateway 600YG2 Top Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway 600YG2 Top Case Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Possible device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Possible device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable and gently pull straight up.
  6. Gateway 600YG2 Top Case Replacement, LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  7. Gateway 600YG2 Top Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the LCD from the system board.
  8. Gateway 600YG2 Top Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  9. Gateway 600YG2 Top Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
  10. Gateway 600YG2 Top Case Replacement, CD/DVD or Floppy drives: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the release and push the button to eject the drive.
    • Remove the drive.
    • When reinserting the drives, put them in the original slot to avoid interface conflicts.
  11. Gateway 600YG2 Top Case Replacement, Top Case: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
  12. Gateway 600YG2 Top Case Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two indicated screws.
  13. Gateway 600YG2 Top Case Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the back of the case.
  14. Gateway 600YG2 Top Case Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Potential for device damage: Failure to properly do this step will damage your mouse pad ribbon.
    • Lift the plug holding the mouse ribbon about 1/16 inch or until it stops
    • Remove the ribbon.
  15. Gateway 600YG2 Top Case Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your spudger between the upper and lower case at the drive bay closest to the battery.
    • Carefully go around the entire case, unseating all plastic clips holding the upper and lower cases together.
  16. Gateway 600YG2 Top Case Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the upper case about 1/4 inch.
    • Unplug the last connecting wire and remove the upper case.
Elizabeth Mazer
crwdns2935283:010/14/10crwdne2935283:0
78 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-10, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 20-10, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S20G10
crwdns2935297:022crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,023
