Gateway 600YG2 System Board Replacement
  1. Gateway 600YG2 System Board Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 System Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery cover using the tab on the right side.
    • Use your index finger to help lift and remove the battery.
  3. Gateway 600YG2 System Board Replacement, CD/DVD or Floppy drives: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the release and push the button to eject the drive.
    • Remove the drive.
    • When reinserting the drives, be sure to put them in the original slot to avoid interface conflicts.
  4. Gateway 600YG2 System Board Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew 1 captive screw holding hard drive cover on.
    • slide hard drive to the right and remove.
    • for detailed pictures and info go to Gateway Support
  5. Gateway 600YG2 System Board Replacement, Power Button Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  6. Gateway 600YG2 System Board Replacement, LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  7. Gateway 600YG2 System Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the LCD from the system board.
  8. Gateway 600YG2 System Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  9. Gateway 600YG2 System Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
  10. Gateway 600YG2 System Board Replacement, Keyboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5 screws holding the keyboard in place.
  11. Gateway 600YG2 System Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway 600YG2 System Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  12. Gateway 600YG2 System Board Replacement, System Fan: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway 600YG2 System Board Replacement, System Fan: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
  13. Gateway 600YG2 System Board Replacement, Top Case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the thirteen screws from the bottom of the computer.
  14. Gateway 600YG2 System Board Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two indicated screws.
  15. Gateway 600YG2 System Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws from the back of the case.
  16. Gateway 600YG2 System Board Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Potential for device damage: Failure to properly do this step will damage your mouse pad ribbon.
    • Lift the plug holding the mouse ribbon about 1/16 inch or until it stops
    • Remove the ribbon.
  17. Gateway 600YG2 System Board Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert your spudger between the upper and lower case at the drive bay closest to the battery.
    • Carefully and slowly go around the entire case, unseating all plastic clips holding the upper and lower cases together.
  18. Gateway 600YG2 System Board Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the upper case about 1/4 inch.
    • At the rear of the case is one last connecting wire. Unplug it and remove the upper case.
  19. Gateway 600YG2 System Board Replacement, System Board: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gateway 600YG2 System Board Replacement, System Board: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 8 screws from drive bays.
  20. Gateway 600YG2 System Board Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 6 5mm hex nuts from back of laptop.
  21. Gateway 600YG2 System Board Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screw
    • Slide metal clip into battery bay
  22. Gateway 600YG2 System Board Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two screws.
    • Hard drive extension should lift out from system board.
  23. Gateway 600YG2 System Board Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 screws holding left speaker for ease of access to connectors and external sound board.
  24. Gateway 600YG2 System Board Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove screw and unplug speakers from external sound board.
    • Lift external soundboard away from system board and remove.
  25. Gateway 600YG2 System Board Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug audio DJ
    • Unplug System status light board
    • Starting on the right side of case gently lift and slide system board till it comes free of lower case.
Elizabeth Mazer
crwdns2935283:010/14/10crwdne2935283:0
78 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-10, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 20-10, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S20G10
crwdns2935297:022crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 2,857
