How to replace or upgrade the CPU
Flip the laptop over.
Slide the battery release tab to the right with your index finger to open the battery cover.
Remove the battery cover using the tab on the right side.
Use your index finger to help lift and remove the battery.
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
Remove the 5 screws holding the keyboard in place.
Follow the black ribbon cable to the connector and gently pull straight up.
Unscrew the four captive screws.
Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
Turn screw 1/4 turn to the right.
