How to replace or upgrade the CPU
Flip the laptop over.
Slide the battery release tab to the right to open the battery cover.
Remove the battery cover using the tab on the right side.
Lift and remove the battery.
Insert the spudger between the "sysrq" and "ins" keys.
Gently pry free the power button panel above the keyboard, from the right and moving to the left.
Remove the five screws holding the keyboard in place.
Follow the black ribbon cable and gently pull straight up.
Unscrew the four captive screws.
Unplug the fan from the system and pull it out. This should slide forward before coming free.
Turn screw 1/4 turn to the right.
