crwdns2950213:0crwdne2950213:0
crwdns2950215:0crwdne2950215:0
crwdns2959928:0crwdne2959928:0 ↓Use this guide to identify the main parts of a gasoline engine before diagnosing or repairing it. A gasoline engine changes the chemical energy stored in fuel into motion. This guide organizes the engine into fixed parts, moving parts, internal components, and external belt-driven components so you can understand what you're looking at before starting deeper repair work.
Safety Glasses4.7
crwdns2955114:01crwdne2955114:0 Prepare the engine safely
Park the vehicle on a level surface, turn off the engine, set the parking brake, and remove the key.
Put on safety glasses and work gloves.
Use a wrench to disconnect the negative battery cable before touching belts, the alternator, the water pump, the cooling fan, or electrical connectors.
crwdns2955114:02crwdne2955114:0 Understand the engine job
Treat the gasoline engine as a system that changes chemical energy in fuel into motion.
Use this idea to trace a problem from fuel energy, to internal movement, to the parts driven outside the engine.
crwdns2955114:03crwdne2955114:0 Sort parts into groups
Divide engine parts into fixed parts and moving parts before identifying them.
Fixed parts stay mounted and support or contain the moving parts.
Moving parts rotate or slide while the engine runs.
crwdns2955114:04crwdne2955114:0 Identify fixed engine parts
Look for the stationary engine structure before looking for rotating or sliding parts.
Identify the cylinder block as the main fixed body of the engine.
Identify the cylinders as the fixed bores inside the block where the pistons move.
crwdns2955114:05crwdne2955114:0 Identify moving internal parts
Identify the pistons as the parts that move inside the cylinders.
Identify the crankshaft as the rotating shaft linked to piston movement.
Identify the camshaft as the shaft that operates the valve timing parts.
Identify the valves as the parts that open and close during engine operation.
crwdns2955114:06crwdne2955114:0 Identify external driven parts
Follow the external belt around the front of the engine.
Identify the alternator as a belt-driven component.
Identify the water pump as a belt-driven component when it is driven by the external belt.
Identify the cooling fan as part of the cooling system shown with the external engine components.
crwdns2955114:07crwdne2955114:0 Plan the repair area
Choose the repair area by matching the symptom to a component group.
Use the fixed group for issues involving the block, cylinders, housings, or mounting structure.
Use the moving group for issues involving pistons, the crankshaft, the camshaft, or valves.
Use the external group for issues involving the belt, alternator, water pump, or cooling fan.
Use this component map as a starting point before diagnosing or disassembling a gasoline engine. Confirm the exact layout for the engine you're working on, because belt routing and component placement can vary. Repair didn't go as planned? Ask our Answers community for help.
