Gasket in the inlet valve
  1. Gasket in the inlet valve, Gasket in the inlet valve: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the side panel and remove the brewing unit.
  2. Gasket in the inlet valve: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gasket in the inlet valve: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the drip tray underneath the brewing unit.
  3. Gasket in the inlet valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gasket in the inlet valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gasket in the inlet valve: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four Torx T10 screws that hold in place the cover of the inlet valve.
    • Remove the cover.
    • Clean well the inside and back panel of this cover.
  4. Gasket in the inlet valve: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Gasket in the inlet valve: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can replace the seals, it's even better if you remove the nozzle completely.
    • Replace the gaskets using a blunt tool, such as a spatula.
    • The upper gasket is larger.
    • Smear the gaskets with silicone grease.
    • To remove the nozzle, you have to unscrew the two T10 Torx screws.
  5. Gasket in the inlet valve: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Gasket in the inlet valve: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Gasket in the inlet valve: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here you see the removed socket. Note the double O-rings. They may get stuck in the opening.
    • Open the valve. To do this, the slot at the upper end must be twisted a little, then the inside comes out. Check the spring, the valve stem and the two seals. When assembling, pay attention to the correct position of the valve stamp: it must point to the water inlet side, otherwise the valve will not open!
    • Replace the seals on the nozzle and lightly grease them with food grade silicone grease.
    • If the two green O-rings no longer seal properly, the valve is no longer working. Replace the seals.
Work through the steps in reverse order to re-assemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
285,049 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 239
crwdns2942667:0crwdne2942667:0 6,458
