Garmin nuviCam LMTHD Battery Replacement
Sarah Myers
crwdns2944107:0crwdnd2944107:0Sarah Myerscrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
This guide will be helpful if you are attempting to replace your nuviCam LMTHD battery. You might have a little trouble opening the device, but it does come off with a little force using the plastic prying tools. You might need to replace the battery if your device is not holding it's charge or the device is over heating. The battery is fairly simple to remove, good luck.
crwdns2944105:0crwdne2944105:0
  1. Garmin nuviCam LMTHD Battery Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin nuviCam LMTHD Battery Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6.9 mm black screws using the T6 screw bit.
    Hi Anybody Knows where I can buy the screen .
    floresmorales063 - crwdns2934203:0crwdne2934203:0
    The screen Is impossible to find.
    Robert - crwdns2934203:0crwdne2934203:0
  2. Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the black and red wire from the screen.
    The little plug on the screen pulls out. Remove the tape carefully.
    Gerald Knoch - crwdns2934203:0crwdne2934203:0
  4. Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
    Is there a secret to reattaching the screen ribbon? Mine won’t go back in the slot.
    Matthew Craven - crwdns2934203:0crwdne2934203:0
  5. Garmin nuviCam LMTHD Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the white box in your device which is the battery.
  6. Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect battery from device pulling the green, red, and black wires from motherboard.
  7. Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect orange cable strip laying across battery by sliding it out of connector .
    • It may be at your benefit to use tweezers. It will be easier to reconnect the orange ribbon later with this tool.
  8. Garmin nuviCam LMTHD Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry battery out of device.
    • Battery is glued into device, so it may be difficult to remove.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Sarah Myers
crwdns2935283:001/19/17crwdne2935283:0
424 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-6, Mathisen Winter 2017 crwdns2935289:0Eastern Washington University, Team 1-6, Mathisen Winter 2017crwdne2935289:0
EWU-MATHISEN-W17S1G6
Where did you buy the battery? What is the voltage/current?
John Justin - crwdns2934203:0crwdne2934203:0
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
Gary - crwdns2934203:0crwdne2934203:0
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
guy.adamson - crwdns2934203:0crwdne2934203:0
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
Zach - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,321
