This guide will be helpful if you are attempting to replace your nuviCam LMTHD battery. You might have a little trouble opening the device, but it does come off with a little force using the plastic prying tools. You might need to replace the battery if your device is not holding it's charge or the device is over heating. The battery is fairly simple to remove, good luck.
Remove the four 6.9 mm black screws using the T6 screw bit.
Pry the device open using a plastic opening tool.
We suggest starting from the dash camera side for easier opening
Disconnect the black and red wire from the screen.
Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
Locate the white box in your device which is the battery.
Disconnect battery from device pulling the green, red, and black wires from motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect orange cable strip laying across battery by sliding it out of connector .
Where did you buy the battery? What is the voltage/current?
It is nice to see how to remove the battery, but would like to have one handy before I start. Where can I buy one and what are the specifications?
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
Anyone else having issues getting it to charge?
Just shows a red battery with a question mark.
