Garmin nuvi 2460 LMT Motherboard Replacement
  1. Garmin nuvi 2460 LMT Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin nuvi 2460 LMT Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Motherboard Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and separate the speaker connector cable using a pair of tweezers.
  6. Garmin nuvi 2460 LMT Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the speaker out of the back cover using a plastic opening tool.
    • Apply force as needed if there is glue holding the speaker in place.
  7. Garmin nuvi 2460 LMT Motherboard Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers, grab the connecting wires and lift the terminal from the motherboard.
    • Avoid contacting battery terminals with metallic objects.
  8. Garmin nuvi 2460 LMT Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the battery out of the back cover using a plastic opening tool.
    • Work the edges and apply force when removing the battery, as it will be glued down.
  9. Garmin nuvi 2460 LMT Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx Screwdriver, unscrew the 5 screws holding the motherboard in place.
  10. Garmin nuvi 2460 LMT Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt and slide the motherboard out of the back cover.
Ricardo Audain
crwdns2935283:009/07/16crwdne2935283:0
671 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-4, Remmell Fall 2016 crwdns2935289:0USF Tampa, Team 6-4, Remmell Fall 2016crwdne2935289:0
USFT-REMMELL-F16S6G4
crwdns2942667:0crwdne2942667:0 489
