Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
Lift the beige clamp using a tweezer or your fingernail and remove the connector.
Lift the connector gently from the socket, making sure you pull in the right direction.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Lift and separate the speaker connector cable using a pair of tweezers.
Gently lift the speaker out of the back cover using a plastic opening tool.
Using a pair of tweezers, grab the connecting wires and lift the terminal from the motherboard.
Pry the battery out of the back cover using a plastic opening tool.
Using a T5 Torx Screwdriver, unscrew the 5 screws holding the motherboard in place.
Tilt and slide the motherboard out of the back cover.
