Garmin inReach Mini Battery Replacement
  1. Garmin inReach Mini Battery Replacement, Nylon Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device on a level surface with the back hard case facing up.
  2. Garmin inReach Mini Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T5 to remove the 1.9mm screw attached to the nylon strap.
    • Remove the nylon strap.
  3. Garmin inReach Mini Battery Replacement, Back Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement, Back Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement, Back Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 1.8 mm screws located on the top, sides, and bottom corners of the backside of the device.
  4. Garmin inReach Mini Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lastly, lift the protective cap on the side of the device that states "SOS". Slowly pull it to the right in order to remove the back hard case.
  5. Garmin inReach Mini Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the precision tweezers with the round tips, detach the battery connector from the motherboard.
    • Disconnecting the battery stops the flow of power into the motherboard. This is for your own safety.
    • If utilizing this guide as a prerequisite to replacing the motherboard, it is crucial not to damage the cable connecting the battery to the motherboard. When the new motherboard is introduced, it will need to be reconnected with that cable.
  6. Garmin inReach Mini Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Mini Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the back hard case, users can access the battery on the inside of the back hard case.
    • Take the iFixit opening tool and insert it into the small crevices on each side of the battery. Once inserted, apply pressure downward in order to lift the battery up. Repeat on all 3 corners.
  7. Garmin inReach Mini Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin inReach Mini Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Create leverage by inserting the opening tool underneath the battery. Lift the battery up until it detaches from the case, then remove the battery entirely.
  8. Garmin inReach Mini Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Then using the precision tweezers with the round tips, lightly pull the battery out from the case.
    • The battery is attached to the back hard case with an adhesive.
    • Dispose of the lithium ion battery in a safe manner in order to prevent electrical hazards. Keep the battery dry and cool.
Ellie Taube
crwdns2935283:009/03/21crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 2-2, Bedsole Fall 2021 crwdns2935289:0University of Alabama, Team 2-2, Bedsole Fall 2021crwdne2935289:0
UA-BEDSOLE-F21S2G2
Any idea where to buy a replacement motherboard? The battery in mine corroded and the battery connector broke off.
Ashley Hill - crwdns2934203:0crwdne2934203:0
where to buy the battery from? is it the same battery for Garmin inReach Mini 2?
Akkad - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 5,478
