Garmin inReach Explorer Plus Antenna Replacement
  1. Garmin inReach Explorer Plus Antenna Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
  3. Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus Antenna Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus Antenna Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement, LCD Screen: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
  10. Garmin inReach Explorer Plus Antenna Replacement, Antenna: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement, Antenna: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin inReach Explorer Plus Antenna Replacement, Antenna: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull out the antenna wire and remove the antenna from the device.
    • The antenna should now slide out easily. If the antenna is stuck, use the spudger to gently dislodge the antenna from its housing.
Sean Kelley
crwdns2935283:009/28/21crwdne2935283:0
387 crwdns2915208:0crwdne2915208:0
Clemson, Team 5-4, Hunter Fall 2021 crwdns2935289:0Clemson, Team 5-4, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S5G4
crwdns2942667:0crwdne2942667:0 757
