This guide uses the iOpener and black spudger to remove the broken screen from the device, allowing for replacement. Screen replacement will compromise waterproof integrity.
Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
Insert a spudger between the display and watch body.
Pry upwards and work the spudger around the perimeter of the display to free it from the body.
Where can you purchase a new screen? A lot of people are having this issue.
Could you find one yet?
What would be cost of replacement of Screen for Garmin Vivo -HR
how to reach the battery
Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
crwdns2935229:016crwdne2935229:0
crwdns2947412:019crwdne2947412:0
Hello,
thanks for this. Where can i buy the new screen?
Nice guide! Thanks. But I can’t find any parts to repair my watch
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
What type of glue i use to connect the display an the body?
I’ve only found a couple sources for the adhesive.
This one is the best way to glue display and body staying flexible and resistant to water and over a wide temperature range.:
Dove è possibile acquistare il dispay per il vivoactive hr??
grazie per l’aiuto
Hello,
thanks for this. Where can i buy the new screen? for this
Hi There
Where did you buy the display?
Regards
Where i can buy the display?
What’s the point of making a how to if we can’t find the parts,
Hi, how to change battery???
Display can be bought there :
Where is the backlight located in all of this?
If only the touch part is broken, you can change only this one. you have to heat the whole and insert a solid wire between the LCD screen and the touch part to separate them. then clean the LCD screen and use a UV glue to glue the new touch screen. it costs half as much as buying the whole thing.
https://fr.aliexpress.com/item/400006421...
Glue: https://fr.aliexpress.com/item/330387129...
UV light for example: https://fr.aliexpress.com/item/328080542...
Where is the backlight located in this thing? Is it built into the screen or something separate?
Hello, is the watch still water resistant, after changing the display?
pre-owned screen from ebay, (new/never used) for £5uk.
The first instruction about entering via the top left corner is nigh on impossible unless you’re willing to damage the plastic surround which is in effect a raised bezel to protect the glass.
Since the reason for swap was a slightly cracked screen, I broke through the corner of the glass and unpeeled the shards of screen from the inner frame using heat and a scalpel to remove the adhesive. I burned through 10 minutes a few times doing this, but once the frame was clear, the replacement process was an absolute breeze.
No gasket/seal was available, so I used 1mm double-sided and followed the frame as a guide, it’s overlapped, but I’d be wary of suggesting it’s still waterproof.
Thanks for the guide, it was super helpful, and without it, I would never have attempted the repair!
I purchased my new screen through Amazon. It will take a month, or so, to get it shipped to you, as it comes from China. Received mine today and have not had chance to install it yet. but it looks good.
