Garmin Vivoactive HR Display Replacement
  1. Garmin Vivoactive HR Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
    Where can you purchase a new screen? A lot of people are having this issue.
    Joshua Clem - crwdns2934203:0crwdne2934203:0
    Could you find one yet?
    e.g.labuschagne -
    What would be cost of replacement of Screen for Garmin Vivo -HR
    Harpreet - crwdns2934203:0crwdne2934203:0
  3. Garmin Vivoactive HR Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive HR Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
crwdns2935229:016crwdne2935229:0
Chris Corry
crwdns2935283:007/05/18crwdne2935283:0
256 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G5, Harley Summer 2018 crwdns2935289:0IUPUI, Team S2-G5, Harley Summer 2018crwdne2935289:0
IUPUI-HARLEY-SU18S2G5
crwdns2947412:019crwdne2947412:0
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - crwdns2934203:0crwdne2934203:0
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - crwdns2934203:0crwdne2934203:0
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - crwdns2934203:0crwdne2934203:0
What type of glue i use to connect the display an the body?
culibrkboj - crwdns2934203:0crwdne2934203:0
This one is the best way to glue display and body staying flexible and resistant to water and over a wide temperature range.:
https://fr.aliexpress.com/item/329544137...
Bruno Junca -
Dove è possibile acquistare il dispay per il vivoactive hr??
grazie per l’aiuto
Michele - crwdns2934203:0crwdne2934203:0
Hello,
thanks for this. Where can i buy the new screen? for this
Darren Letten - crwdns2934203:0crwdne2934203:0
Hi There
Where did you buy the display?
Regards
pearlduck -
Where i can buy the display?
pearlduck -
What’s the point of making a how to if we can’t find the parts,
Shailendra Khatri - crwdns2934203:0crwdne2934203:0
Where is the backlight located in all of this?
Sam - crwdns2934203:0crwdne2934203:0
If only the touch part is broken, you can change only this one.  you have to heat the whole and insert a solid wire between the LCD screen and the touch part to separate them.  then clean the LCD screen and use a UV glue to glue the new touch screen.  it costs half as much as buying the whole thing.
https://fr.aliexpress.com/item/400006421...
Glue: https://fr.aliexpress.com/item/330387129...
UV light for example: https://fr.aliexpress.com/item/328080542...
Bruno Junca - crwdns2934203:0crwdne2934203:0
Where is the backlight located in this thing? Is it built into the screen or something separate?
Hello, is the watch still water resistant, after changing the display?
Mr. GóÒdKaT - crwdns2934203:0crwdne2934203:0
pre-owned screen from ebay, (new/never used) for £5uk.
The first instruction about entering via the top left corner is nigh on impossible unless you’re willing to damage the plastic surround which is in effect a raised bezel to protect the glass.
Since the reason for swap was a slightly cracked screen, I broke through the corner of the glass and unpeeled the shards of screen from the inner frame using heat and a scalpel to remove the adhesive. I burned through 10 minutes a few times doing this, but once the frame was clear, the replacement process was an absolute breeze.
No gasket/seal was available, so I used 1mm double-sided and followed the frame as a guide, it’s overlapped, but I’d be wary of suggesting it’s still waterproof.
Thanks for the guide, it was super helpful, and without it, I would never have attempted the repair!
Womble Messiah - crwdns2934203:0crwdne2934203:0
I purchased my new screen through Amazon. It will take a month, or so, to get it shipped to you, as it comes from China. Received mine today and have not had chance to install it yet. but it looks good.
eaglerest - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 63
crwdns2942667:0crwdne2942667:0 26,697
