Garmin Vivoactive Display Unit Replacement
    1. Garmin Vivoactive Display Unit Replacement, Wristband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
    2. Garmin Vivoactive Display Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive Display Unit Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
    1. Garmin Vivoactive Display Unit Replacement, Display Unit: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
    2. Garmin Vivoactive Display Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive Display Unit Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
    3. Garmin Vivoactive Display Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
    4. Garmin Vivoactive Display Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
    5. Garmin Vivoactive Display Unit Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
    6. Garmin Vivoactive Display Unit Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
crwdns2935229:016crwdne2935229:0
Katie Paswaters
crwdns2935283:010/01/15crwdne2935283:0
532 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-21, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 1-21, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S1G21
crwdns2947412:040crwdne2947412:0
Does anyone knows where can I buy a vivoactive display?
dragomariano - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Any links found for replacement screen?
dskggray - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 218
crwdns2942667:0crwdne2942667:0 105,675
