Garmin Vivoactive Battery Replacement
crwdns2869540:0crwdne2869540:0: 117 k
crwdns2942659:0crwdne2942659:0
crwdns2942661:0crwdne2942661:0
11
crwdns2942663:0crwdne2942663:0
86
crwdns2942665:0crwdne2942665:0
365
crwdns2942667:0crwdne2942667:0
116 611
crwdns2955950:0crwdne2955950:0: 32
crwdns2947424:03crwdne2947424:0, crwdns2947420:029crwdne2947420:0
crwdns2947416:0crwdne2947416:0
Completed: 17
crwdns2944095:017crwdne2944095:0
Favorites: 2
crwdns2944103:02crwdne2944103:0
crwdns2955944:0crwdne2955944:0: 5 - 15 crwdns2931279:0crwdne2931279:0
crwdns2942287:0crwdne2942287:0 ↓
After many cycles of charging and discharging, batteries become fatigued and lose their capacity to hold a charge. Manufacturing defects and improper storage can also lead to your watch battery not being as efficient as it once was. This straightforward guide will walk you through the steps of replacing your battery whatever the cause of its failure.
This procedure will fix any current problems you have with your battery. We also recommend you take the time to learn about proper charging and storage techniques to get the maximum life cycle out of your battery. Some of the basic steps points include:
  • Store the device in a room temperature space out of direct sunlight
  • Charge the device daily or at least every other day
  • Do not let it discharge below 5%
Otherwise we hope this process goes well for you, good luck!
    1. Garmin Vivoactive Battery Replacement, Wristband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
    2. Garmin Vivoactive Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
    1. Garmin Vivoactive Battery Replacement, Display Unit: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
    2. Garmin Vivoactive Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
    3. Garmin Vivoactive Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
    4. Garmin Vivoactive Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
    5. Garmin Vivoactive Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
    6. Garmin Vivoactive Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
    1. Garmin Vivoactive Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Follow previous guides until you've exposed the battery as shown.
      • Begin by removing the battery connector tab.
      • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
    2. Garmin Vivoactive Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening pick to gently pry out the battery as shown.
      • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
    3. Garmin Vivoactive Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Vivoactive Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Vivoactive Battery Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With the battery loose from the case, rotate it to expose the attached tab
      • Gently pry up the attached tab with a fingernail.
      • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
crwdns2935229:017crwdne2935229:0
Michael Clark
crwdns2935283:010/01/15crwdne2935283:0
679 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-21, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 1-21, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S1G21
crwdns2947412:029crwdne2947412:0
I have the Same question... where can i buy the replacement?
Roli - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I've tried everywhere to find a battery for my vivoactive, with no luck. Where should I look to find a battery? HELP!
David - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Battery is a 3.7 V, 150 mAh Li-Polymer type.
Gary K - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 86
crwdns2936753:030crwdne2936753:0 365
crwdns2942667:0crwdne2942667:0 116,611
