For the replacement I used:
new battery, boiling water, knife, suction cup, plastic wedge, screw driver, double sided tape, t-7000 glue
1. remove the wrist band
2. boil 1L water
crwdns2935267:0crwdne2935267:0iOpener$12.99
If you use water, let the boiling water rest for 60 sec then pour the water over the display
Make sure to dry the watch before removing the display!
To remove the display, a knife was used to separate the display, along with a suction cup
Great - worked for me. I found pushing the knife square into the groove gave good release.
I found the boiling water worked best. Couldn't get it to release just using a heat gun.
Remove the two connected FPCs
Remove the 3 screws, then lift the PCB
Remove the old battery
Next, add double sided tape to the new battery. Make sure to connect and place the new battery inside the watch
T7000 adhesive has a short open working time before it skins over. Move quickly to close up the assembly after applying T7000 to the bezel "U" channel!
After completing the battery replacement, everything worked except the TOUCH function on the display. The solution was to power off the watch [hold button in for 15 seconds] wait 15 seconds and then power the watch on [hold button in for 15 seconds] again. Now it is 100% functioning again with the new battery.
To reassemble your device, follow the steps in reverse order.
crwdns2935229:05crwdne2935229:0
crwdns2947412:05crwdne2947412:0
do you have the same instructions for a garmin vivoactive music 3?
Very clear and excellent presentation. Clarity of images. Succinct and effective descriptions of steps and tips. Very helpful colored circle markings.
Questions :
1. Tool used to separate FPC's ?
2. Tool used to reattach FPC's ?
3. Some people have spoken of battery wires disconnecting from plastic connector fitting during separation/removal. What did you use to disconnect the battery connector fitting ?
4. Type of double sided tape used ?
5. Where double sided tape applied ? (There is original tape on original battery to demonstrate ?)
6. Did you apply new glue to only the underside rim of the watch face ?
7. How were you careful to avoid excess glue contacting circuit board upon re-attachment of watch face ?
8. Und jetzt habe ich Durst auf ein würziges Brauerei Wagner Kupferstich Rotbier! : )
Perfekte Anleitung!
Der Trick mit dem Wasser ist Gold wert, wenn man seine Elektronik nicht mit dem Fön „grillen“ möchte. Uhr läuft wieder wie in den ersten Tagen. Danke dafür!
Vielleicht sollte man noch erwähnen, dass der Batterieconnector einfach nach oben abgezogen und genau so wieder draufgesteckt werden kann.
Gibt es eine Empfehlung für einen neuen guten Akku? Evtl mit Adresse
The battery connector does not slide out of its seat horizontally. It has tabs on the side of the connector that prevent it from doing so. Instead, the connector lifts up and out of its seat. Use of pair of tweezers to lift the end where the wires connect up and then out of the seat at a 45 degree angle. Install the new battery connector in reverse order.
Before beginning, use the Garmin Express desktop {Utilities] function to [BACKUP] your device settings.
stuff94 - crwdns2934203:0crwdne2934203:0
When heating the watch to remove the display, note it is a narrow "U" shaped channel under the metal exterior bezel that holds the glue you are trying to soften.
