Garmin Vivoactive 3 Battery Replacement
  1. Garmin Vivoactive 3 Battery Replacement, preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For the replacement I used:
    • new battery, boiling water, knife, suction cup, plastic wedge, screw driver, double sided tape, t-7000 glue
    • 1. remove the wrist band
    • 2. boil 1L water
  2. Garmin Vivoactive 3 Battery Replacement, heat up the display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive 3 Battery Replacement, heat up the display: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    iOpener
    $12.99
    • If you use water, let the boiling water rest for 60 sec then pour the water over the display
    • Make sure to dry the watch before removing the display!
    • Although hot water was used in this guide, you can always use an iOpener as an alternative
    • To remove the display, a knife was used to separate the display, along with a suction cup
  3. Garmin Vivoactive 3 Battery Replacement, disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Vivoactive 3 Battery Replacement, disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two connected FPCs
    • The FPC's are different connectors, and have been color coded for easy reassembly
    • Make sure to clean off any glue or glue residue left behind.
    • Remove the 3 screws, then lift the PCB
  4. Garmin Vivoactive 3 Battery Replacement, battery replacement & assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If needed, remove the red marked FPC to increase assembly space
    • Remove the old battery
    • Next, add double sided tape to the new battery. Make sure to connect and place the new battery inside the watch
    • Make sure to use a good electronic adhesive (t-7000) to seal the display again
To reassemble your device, follow the steps in reverse order.
crwdns2935229:05crwdne2935229:0
Daniel Alexander
crwdns2935283:012/23/20crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
do you have the same instructions for a garmin vivoactive music 3?
jonas rogge - crwdns2934203:0crwdne2934203:0
Very clear and excellent presentation. Clarity of images. Succinct and effective descriptions of steps and tips. Very helpful colored circle markings.
Questions :
1. Tool used to separate FPC's ?
2. Tool used to reattach FPC's ?
3. Some people have spoken of battery wires disconnecting from plastic connector fitting during separation/removal. What did you use to disconnect the battery connector fitting ?
4. Type of double sided tape used ?
5. Where double sided tape applied ? (There is original tape on original battery to demonstrate ?)
6. Did you apply new glue to only the underside rim of the watch face ?
7. How were you careful to avoid excess glue contacting circuit board upon re-attachment of watch face ?
8. Und jetzt habe ich Durst auf ein würziges Brauerei Wagner Kupferstich Rotbier! : )
Dave - crwdns2934203:0crwdne2934203:0
Perfekte Anleitung!
Der Trick mit dem Wasser ist Gold wert, wenn man seine Elektronik nicht mit dem Fön „grillen“ möchte. Uhr läuft wieder wie in den ersten Tagen. Danke dafür!
Vielleicht sollte man noch erwähnen, dass der Batterieconnector einfach nach oben abgezogen und genau so wieder draufgesteckt werden kann.
MichaelS - crwdns2934203:0crwdne2934203:0
Gibt es eine Empfehlung für einen neuen guten Akku? Evtl mit Adresse
andi76 - crwdns2934203:0crwdne2934203:0
The battery connector does not slide out of its seat horizontally. It has tabs on the side of the connector that prevent it from doing so. Instead, the connector lifts up and out of its seat. Use of pair of tweezers to lift the end where the wires connect up and then out of the seat at a 45 degree angle. Install the new battery connector in reverse order.
Mark Boling - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 115
crwdns2936753:030crwdne2936753:0 471
crwdns2942667:0crwdne2942667:0 9,028
