Replacing the watch band, strap, or bracelet of the Garmin Vívoactive 4 (M/N: 03618) is quite simple and requires no external tools.
There are many reasons why you may want to replace your watch band. For example, they may be damaged, you may be sensitive to the material, or it may not be the correct size for you. The watch band connection to the housing may be loose (see Loose Wristband Connection in the Vívoactive 4 Troubleshooting Guide).
Please note:
- It's important to not force the watch parts into or out of place, as it could damage the device.
- If you have difficulty moving the pin with your fingers, consider using a spudger for assistance.
- All parts in this guide should fit smoothly without excessive force.
Flip the watch on its back to reveal the watch band connection pins.
Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
Push on the pin to release the strap from it's hinge.
Pull the strap away from the watch to disconnect it.
