Garmin StreetPilot c320 Rear Case Assembly Replacement
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin StreetPilot c320 Rear Case Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Andrew Burman
crwdns2935283:001/18/12crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-19, Maness Winter 2012 crwdns2935289:0Cal Poly, Team 11-19, Maness Winter 2012crwdne2935289:0
CPSU-MANESS-W12S11G19
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,464
