Garmin StreetPilot C330 Outer Casing Replacement
  1. Garmin StreetPilot C330 Outer Casing Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement, Outer Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot C330 Outer Casing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
Adrian Leon
crwdns2935283:010/07/10crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 22-1, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 22-1, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S22G1
crwdns2942667:0crwdne2942667:0 2,018
