If you need to replace the backing of a Garmin STRIKER 4, access it with this guide. Some reasons you may be replacing the backing include corroded pins and the device not charging.
Flip the device so the back is facing up.
Remove all six 6 mm screws using a Phillips #0 screwdriver.
Detach and flip the backside to open the device.
