Garmin Rino 700 Satellite Antenna Replacement
  1. Garmin Rino 700 Satellite Antenna Replacement, Battery Disconnect: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Satellite Antenna Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
  6. Garmin Rino 700 Satellite Antenna Replacement, Satellite Antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement, Satellite Antenna: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Rino 700 Satellite Antenna Replacement, Satellite Antenna: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently and delicately heat up the solder holding the antenna port to the motherboard.
    • Carefully remove the antenna with the tweezers and set it aside.
    • Refer to the How To Solder and Desolder Connections for a guide on soldering.
Abigail Dugan
crwdns2935283:009/28/21crwdne2935283:0
512 crwdns2915208:0crwdne2915208:0
Clemson, Team 5-5, Hunter Fall 2021 crwdns2935289:0Clemson, Team 5-5, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S5G5
crwdns2942667:0crwdne2942667:0 336
