Garmin Nuvi 680 Antenna Replacement
  1. Garmin Nuvi 680 Antenna Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the antenna on the back of the device and gently flip it open to reveal the screws underneath.
    • Remove the two 4.42 mm screws in the top-left and top-right corners of the antenna cover using a T5 Torx screwdriver
  2. Garmin Nuvi 680 Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna cover.
    • Set the removed cover aside carefully.
  3. Garmin Nuvi 680 Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The yellow wire is connected to the motherboard. Do not disconnect it until you finish opening the device.
    • Locate the green antenna circuit board in the middle of the case.
    • Gently use 1 or 2 fingers to grab and pull the antenna circuit board out of the middle of the case.
  4. Garmin Nuvi 680 Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 680 Antenna Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of a spudger into the leftmost slit at the top of the antenna case, where you previously removed the circuit board
    • Once the spudger is inserted into the leftmost end of the slit at the top of the antenna case, slide it to the rightmost side of the slit.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the antenna assembly, which is now exposed after removing the antenna cover.
    • The two screws are positioned at the top-left and top-right corners of the antenna assembly
    • Use a T5 Torx screwdriver to remove the 10.82 mm screws from the top-left and top-right corners of the antenna assembly.
  6. Garmin Nuvi 680 Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 680 Antenna Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the top side of the outer case.
    • Using your iFixit Opening Tool, gently insert a flat end of the tool into the slit of the top cover.
    • Use the Opening Tool and your hands to pull apart the front and back of the device. Grip the top and bottom sides with your hand while inserting the tool into the slit to gently separate the two halves
    • One end of the front and back of the outer case are still connected by ribbon cables.
  7. Garmin Nuvi 680 Antenna Replacement, Antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 680 Antenna Replacement, Antenna: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
    The antenna ribbon cable has a latch that must be lifted first. It's a light muddy brown color. It flips up and away in the opposite direction of the ribbon cable.
    ewkpates - crwdns2934203:0crwdne2934203:0
Chris Marzano
crwdns2935283:001/20/11crwdne2935283:0
968 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-22, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 5-22, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S5G22
Where can you find the replacment antenna?
All I see is external antennas on the net.
Dennis - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 4,495
