Garmin Nuvi 50LM LCD Touchscreen Replacement
  1. Garmin Nuvi 50LM LCD Touchscreen Replacement, LCD Touchscreen Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure the LCD screen is face down on a flat surface.
    • Make sure the side containing the speaker and the charging port is facing up on a flat surface.
  2. Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 9mm screws on the back of the GPS unit with the T4 mini screwdriver found in the iFixit Pro Tech Tool Kit.
  3. Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently use the two blue plastic opening tools from the 70 piece iFixit Pro Tech Tool Kit to open the GPS unit.
    • Be careful not to damage the orange ribbon cord and the motherboard.
    be very careful when opening your garmin - it is exceptionally easy to “tear” the yellow flexible connector if you are not aware of this connector -then the garmin is scrap
    Alfred - crwdns2934203:0crwdne2934203:0
  4. Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the GPS unit is open, gently separate the orange ribbon cord connecting the LCD to the motherboard. Separate the cord at the motherboard.
  5. Garmin Nuvi 50LM LCD Touchscreen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the replacement LCD screen, plug the orange ribbon cord into the motherboard.
Maurice Thomas
crwdns2935283:010/13/15crwdne2935283:0
664 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 2-7, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 2-7, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S2G7
where do you get the replacement screen
Fred - crwdns2934203:0crwdne2934203:0
Hi. Just a quick word to avoid confusion on these units. There is more than one model, and they are quite different in their design, both in the screen design and how it’s fitted together.
The model I have with me (I’m fixing the cracked touch panel) is held together by the same 4 screws as shown here, but the screen looks far more modern. The one shown in this guide appears to be the old style of touch panel, these have a kind of hazy appearance to them. The model I have, which is still named DriveSmart 50LM, has a full width real glass touch panel and is a far more rectangular design. It’s also extremely tight to crack apart the casing once the screws are removed.
Also mine has the same size of circuit inside, but looks far more complicated that the one here, with no circuit shielding, and a MIC on a length of wire that also needs removing (it just plugs in to a space inside).
I’ll try to find time to write a guide for this other model while I have it.
Thanks for creating this guide all of you :)
philpeacock - crwdns2934203:0crwdne2934203:0
Ouch! Thanks for your post philpeacock. I wish I would’ve read it before I ordered the exact same part number, but got something that
I’m pretty sure can’t fit.
David Greene - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,583
