Before replacing the battery, visit this device's troubleshooting page to determine whether you need to replace the battery. Follow the steps in this guide if you need to replace the battery.
Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
Pry the GPS open using a plastic opening tool.
Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
Move the motherboard from from its designated location on the GPS.
Gently unplug the red, green, and black bundled cable to remove the battery.
Use blue plastic opening tool to carefully pry the battery from the GPS.
on my Nuvi 55-diconnected ribbon cable by accident. When I reconnect I get a white screen. How to get the terminals to line up correctly?
