Garmin Nuvi 2797LMT LCD Screen Replacement
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 2797LMT LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
baileykaytar
crwdns2935283:010/13/15crwdne2935283:0
366 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 2-6, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 2-6, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S2G6
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - crwdns2934203:0crwdne2934203:0
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,520
