This guide will help you replace your battery in a few short steps.
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
With the device open, locate the battery with its wire connector plugged into the motherboard. Now delicately detach the battery connector from the center by inserting a spudger underneath the power wire and lift up.
Now using the small plastic opening tool, pry the battery up from the sides.
Your sub-par tools broke when following the directions exactly. Last time I'll be purchasing any of your items, and Ill be disputing the charges on my card for this kit.
Thanks.
But before I get going, which model or type of battery do I need. Garmin does not seem to sell them separately as far as I can see.
GregM
Instructions very lacking. To replace the battery go to https://www.youtube.com/watch?v=OcoZC2Fk.... Much, much better instructions.
insert space between numerals and units (e.g., 4 mm).
Brian Blackburne - crwdns2934203:0crwdne2934203:0
