Garmin Nuvi 2689LMT Microphone Replacement
  1. Garmin Nuvi 2689LMT Microphone Replacement, Microphone: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by taking off the stand by depressing the table turning the round piece back toward you, pulling it away for the Garmin device.
  2. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 bit on a screwdriver to remove the 4 screws at the 4 corners on the back of the device.
    • Right to tighten, left to loosen.
  3. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the device face down on a flat surface, with the bottom facing you.
    • Pry open the seam with a prying tool .
    • There are two seams, the top one is artificial.
  4. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Firmly force a plastic spudger into the bottom seam and pry open a section of the device
    • Use a prying/pushing motion to force the tool into the device until there is a click
    • Repeat all the way around the seam until the back comes off.
  5. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the seam is completely separated, lift the back away from the screen.
    • Do not attempt to separate the unit until all the tabs have been separated.
  6. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge an angled plastic prying tool under the connector to the battery where the wires attach to the mother board
    • Gently pry up the connector. It should come free easily.
    • The battery is connected to the main circuit board by two wires, that are red and green and is attached to a white connector.
  7. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Melt the two metal connections on the circuit board using a soldering iron.
    • Remove the wires using tweezers.
    • There are two wires that are connected to the main circuit board.
    • Soldering irons will reach extremely high temperatures and should be used with caution.
  8. Garmin Nuvi 2689LMT Microphone Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Retrieve your new microphone for your Garmin device and attach to the circuit board with the soldering iron.
    • Carefully melt the solder onto the wire at the connection points on circuit board.
    • Keep the solder on the metal contact point and avoid heating the plastic circuit board to prevent damage.
Allyson Smith
crwdns2935283:009/26/16crwdne2935283:0
114 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 16-5, Eyestone Fall 2016 crwdns2935289:0USF Tampa, Team 16-5, Eyestone Fall 2016crwdne2935289:0
USFT-EYESTONE-F16S16G5
Great explanation, thank you! But where can I buy the replacement mic, please?
André Kobzar - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 331
