This guide will walk you through the process of replacing a faulty or broken battery in your Garmin Nuvi 2597LMT. You may need this guide to replace the battery if you know it is broken, it won't charge, or if you just want to replace the battery. Make sure you are very careful when working with your device; you don't want to break any of the fragile components inside or rip the ribbon cable connecting the two halves.
Turn your device over so the back is revealed and you can see the screws in the four corners.
Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along the sides and the top seams if need be.
Locate the battery and then use your spudger to gently lift the battery, which is held to the case using a sticky pad, and free it from its position.
Use your hands or a spudger to gently lift the wires from underneath to disconnect the connector from the motherboard.
crwdns2935229:08crwdne2935229:0
Great guide. The only thing I might add is you may need magnifiers to see which side of the connector goes down as you reverse step 4. I bought a set of Husky star drivers on Amazon. The bits store in the handle so easy to keep. Start to finish on this job with this guide was maybe 15 minutes. Thanks.
Great guide, just a little tip. BEFORE dismantling old battery connector from the motherboard, put a dab of Tippex on it so you can match the 'upside' to the new battery connector. Just makes re-attaching that bit easier...
I needed to know what size Torx driver I needed. Thank you! This is very easy to follow. I’m sure I’ll have no problems now replacing my battery.
myfblogin - crwdns2934203:0crwdne2934203:0
